Home > Technical (L405) > Sunroof drain points
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Evening all,
just doing a bit of annual maintenance on the L405, just wondering if anyone knows where the sunroof drains exit the vehicle, I have pano opening roof if that makes any difference, I have a small thin clear pipe which exits behind rear wheel on drivers side but cant see anything on passenger side?
Thanks Thumbs Up
Post #665656 1st Jun 2023 5:29pm
MarianaWestminster
That small clear pipe exiting behind the drivers side rear wheel is the drain for fuel filler area.
I know this because mine jettisoned from the vehicle today!
Post #665669 1st Jun 2023 8:16pm
DrF
Thank you, that makes sense. I wonder were the sunroof drains to then??
Post #665717 2nd Jun 2023 12:01pm
numbers 6 and 4 drF..
Post #665723 2nd Jun 2023 12:21pm
DrF
Thanks Stan, that's very helpful. I assume they discharge into wheel arch somewhere or maybe even under the car?? was going to make sure they were running free when I wash it.
Post #665726 2nd Jun 2023 12:37pm
Thumbs Up ... - .- -.
Post #665729 2nd Jun 2023 1:05pm
DrF
Thanks Stan Thumbs Up Thumbs Up
Post #665731 2nd Jun 2023 1:12pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
what's the best way to clear these out? First time FFRR owner
Post #665739 2nd Jun 2023 2:41pm
DrF
I currently don't know, I am trying to figure this out. I am thinking a bit of strimmer wire that I am pretty sure someone said they used and plenty of time!! that is, if I can find out where they exit the vehicle in the wheel arch. I am slightly nervous of cleaning from top down just incase i dislodge the connection from roof to pipe as they appear to be fragile, so was going to go gingerly upwards (excuse the pun!) to avoid the joint and then do the same downwards and hopefully all will be good. Thumbs Up Thumbs Up
Post #665745 2nd Jun 2023 3:21pm
Arch Stanton
would an air line be too fierce? First time FFRR owner
Post #665769 2nd Jun 2023 7:10pm
