Home > In Car Electronics (L322) > Radio volume
Fullfatfan
2012 Range Rover Westminster TDV8 Orkney Grey
Radio volume
Hi all, my apologies if this has been asked before, I’ve searched high and low and all point in between,
When turning ignition on or starting car the radio is a little too loud, is there a way to save start volume to a low setting so as I don’t annoy neighbours at 4.30 am when going to work 😀😀
I’d sooner it be virtually silent at start then turn up after I’ve set off.
Thanks in advance
2012 FFRR
Post #670578 6th Aug 2023 6:00pm
JMC
I've always found that it starts at the volume when it was last used. Turn it down before switching off! Quiet at 5pm can seem a lot louder in the small hours of the morning! Wink The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #670585 6th Aug 2023 6:58pm
Fullfatfan
I’ve tried that and got no joy, still comes on not overly loud but it’s loud enough 🤣🤣
Post #670587 6th Aug 2023 8:48pm
there should be preset audio levels in the sound settings ... - .- -.
Post #670588 6th Aug 2023 9:17pm
