Home > General > non-sport mode tiptronic gearbox?
dwillerton
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Is there any way of using the tiptronic gearbox without engaging sport mode? (2007 TdV8)
I find it bizarre that when tiptronic is activated it always drops a gear, tells you it's in sports mode but it isn't until you change gear that you can see on the dash what gear you are in.
Or should I read the manual?
Post #425 2nd Oct 2007 10:31am
I think that's your lot!
Seems to be the same on all Auto/Tiptronic/Steptronic auto boxes.
When you flip it over to Manual, the Sport mode engages as this is the Auto box controlling still, full auto Sport mode, then to take full manual control you need to flip between the gears. Discovery 4 HSE
Post #426 7th Oct 2007 6:30pm
