Home > In Car Electronics (L322) > 2012 Rear Entertainment - Bluetooth headphone upgrade?
dsm
Good day all,
I've recently bought (another) L322. This is a 2012 model with the rear entertainment screens, but no headphones. Instead of buying second-hand IR headphones on eBay, I'm wondering if I could splice a Bluetooth transmitter into the wiring of the IR transmitter so I could use normal Bluetooth headphones instead.
The wiring diagram has two "LH Audio +VE" and two "RH Audio +VE" connections, presumably one for each screen so I guess I'd need two Bluetooth transmitters. Has anyone got any experience of doing something like this? Are these wires carrying normal line-level analog signals, or something weird?
This is the kind of Bluetooth transmitter I'm talking about:
https://www.amazon.com/UGREEN-Bluetooth-Ad...B099K591CG
Many thanks for any advice!
Post #664974 25th May 2023 2:13am
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Gotta be worth a shot. Would improve the system for a lot of users no end. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #664990 25th May 2023 8:48am
dsm
Good news! I put one end of a chopped-up jack lead into the connector pins (picture below), plugged in some headphones and got sound.
Looking at the connector in the picture, the three wires on the left are for the left screen (orange = right, green = left, black = ground), and the next three are for the right screen (yellow= left, blue=right, black = ground).
It's a bit tight up there so I'll have a look at the other end by the power amp to see if there's more room to splice in my Bluetooth transmitters.
Post #665260 27th May 2023 10:17pm
Danb_220_2019
Be a handy way to add a socket for wired headphones, or a BT transmitter to allow the front seat passenger to listen to the audio for a DVD while the front output is muted. Annoys me that the wife can watch a DVD but I have to listen to it while I'm driving. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Post #665261 27th May 2023 10:30pm
dsm
Install complete. It works, but the sound quality is pretty poor. I need to do some more investigation to work out where the problem is.
This is what I did:
Step 1. Prepare a couple of 3.5mm jack leads for connecting to T-taps
Step 2. Connect T-taps to headphone unit. Note: wire colours are different on the headphone unit.
Step 3. Take 12V power from the red and black cables on pins 1 and 2, and connect it all up.
Post #665346 29th May 2023 2:09am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
first of all you connected two recievers in parallel it is mistake.. You should connect transmiter directly to the plug. Second issue may be impedance mismatch.
Post #665364 29th May 2023 9:52am
dsm
That's a good point, it sounds like some frequencies are more attenuated than others. I'll buy a new connector and wire the BT transmitters directly to that.
Post #665394 29th May 2023 3:01pm
dsm
Just finished, and it works like a charm! I believe the L405, Sport, and the Evoque use similar IR headphones so this will probably work on them too.
I've made a PDF of instructions for anyone else wanting to repeat it.
https://www.fullfatrr.com/gallery/albums/u...pgrade.pdf
Post #665786 3rd Jun 2023 4:12am
