Home > Technical (L460) > Engine fan very active on P530
dc44back
Hi all,
My engine fan comes on almost every trip despite them being no more than 15 mins or so max.
Is this normal?
Didn’t happen on my 5.0SCAB Sport.
I have the P530 BMW engine.
Seems overly sensitive to have the fan come on aggressively every time I do a short journey. And the av temp in London is 15-18c only…
Post #664836 23rd May 2023 10:34pm
Philip
I suppose there will be higher under-bonnet temps with a hot-vee engine.
Post #664837 23rd May 2023 11:13pm
5.0
I have a P530 and have not noticed a fan come on at all. Long or short journeys. Maybe it depends on how much the turbos have been running beforehand.
Post #664853 24th May 2023 7:20am
Dolphinboy
check thermostat housing, possible damage? Thermostat misreading internal engine temps? (happened on my 4.4 TDV8)
Post #664858 24th May 2023 7:58am
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
This is normal for this engine and emissions tech. It’s to do with the PPF as I understand it. The Audi/Bentley/Lambo V8 does the same.
My two P530 have been the same as yours.
Post #664877 24th May 2023 10:28am
CS
Just by way of amplification of the comment from Autobiography: see the 'Harry's Garage' youtube video on the Bentayga 4.0 in which he comments on the frequent fan operation required in 'hot V' twin turbos. Only Range Rovers since 1988
Post #664888 24th May 2023 11:10am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
The thing I notice is when I get home and switch off, the fan runs for quite a while. letters not necessarily in the right order
Post #664892 24th May 2023 11:22am
5.0
I am beginning to wonder if my fan isn't working now Laughing
Post #664948 24th May 2023 7:49pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Yes the fans run on from. I was told its so the engine doesn't cook itself, mine does the same and is normal according to factory. Thumbs Up Advice I was given was if driven hard or for a long time allow engine to idle for a few seconds before you shut down, that will help as well.
Post #664949 24th May 2023 8:06pm
