Home > In Car Electronics (L322) > Infotainment issue - Could I have some advice?
Charles B
Hello. TDV8 4.4 Autobiography 2011
My problem is this. When I start the car the screen powers up with the Range Rover Logo and the light on the power button flashes. Thats it. To make it work, I need to access the fuse box, Pull the main connector, replace it, and as if by magic everything works again until I turn it off and the cycle starts again. When it's working everything works. Cameras, DVD, Radio, SatNav, sound. Any ideas?
With many thanks,
Post #664794 23rd May 2023 3:37pm
daveturbo
audio Issues
I have the same problem,i also changed my rear fuse box which still gave me the same problem (my glovebox will not open top or bottom), so if needed i can send you my fusebox for you to try. Mercedes AMG w207
E class Cabriolet
Overfinch L322 4.4 tdv8
1987 sierra rs cosworth 3 door white.
1985 escort rs turbo series one.
1992 sierra sapphire 4x4 cosworth red
1993 sierra sapphire cosworth 4x4 silver
1993 sierra sapphire cosworth 4x4 white
1995 ducati 916sp.
Post #673899 20th Sep 2023 10:56am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Is a small “+” symbol being displayed after power up ? If so the unit is in touch screen calibration mode. TDV8 4.4 2012
Post #673912 20th Sep 2023 2:10pm
garyRR
The logo plus flashing orange light signifies a MOST network issue.
On the late L322s, this seems to be caused by a faulty TV module.
Best way to find the culprit is to buy a female fibre optic loop on ebay/amazon and test one by one. 2015 Range Rover Autobiography 4.4 SDV8
Post #673947 20th Sep 2023 10:52pm
Exactly that as above... To add, the MOST ring adaptor is often sold as an Audi tool Thumbs Up
Post #673948 20th Sep 2023 11:43pm
daveturbo
Audio Issues
Thank you Guys,i will order one. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #675136 9th Oct 2023 11:07am
