Home > Technical (L322) > Adaptive Dynamic Fault
Bennyis01
England 2010 Range Rover Vogue SE TDV8 Zambezi Silver
morning all
looking for some help with this, I've recently had AC pipe replaced on RR VOGUE 3.6LTR L322 2010.
This ran from front to back of engine down LHS opposite battery bay.
Ever since this has been done I've had an adaptive dynamic fault which will not clear.(coincidence or not)
ive checked wiring on front struts from sensors which are all ok, i haven't checked back ones as ive never had a fault with these , but ive checked faults with iid tool and voltage to each is constant and even, and there are no error codes pointing to them.
my question is are there cables or plugs which may have been disconnected at rear of engine whilst fitting the AC pipe which can be giving me this problem
thanks in advance
jason
Post #664749 23rd May 2023 8:10am
Fill in your car details on your profile, you don't have to say which model you have every time then...
Tell us the code of the fault, this will help, someone will have had it before I imagine... Thumbs Up Pete
Post #664757 23rd May 2023 8:47am
dhallworth
Adaptive Dynamics faults on an L322 are quite often caused by broken wires in the loom that enters the top of the shock absorber.
Have a look at them just as they go into the cap on top of the shock.
Post #664775 23rd May 2023 12:44pm
DrRob
Ideally it needs codes read with something like a GAP IID Bluetooth which will pin point the issue. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #664776 23rd May 2023 12:56pm
Bennyis01
Guys thanks for all your reply, I've managed to find some time and put a code reader on to find fault and it came back with these. Hope these are of some help.
Thanks again
Jason
Post #668002 30th Jun 2023 6:13pm
