Trigger wire upgrade gone wrong and killed starter solenoid | |
Hi all,
Well after doing some further investigations this afternoon the problem with my car was not with the immobiliser (https://www.fullfatrr.com/forum/topic66871.html) but with a dead starter motor, which in turn was a result of an idiotic mistake I made with the trigger wire upgrade. Here is what happened and my view of what went wrong. Let it be a lesson to all - don't let an idiot (me) near your car.
I spent Saturday afternoon getting the car on axles stands, removing the O/S wheel and liner and attaching the upgraded trigger wire to the starter solenoid (leaving the OE wire in-place. Having put everything back together, I started the car and put it back on the drive. On Sunday morning (after disconnecting the negative battery cable and having the alarm go off) I spliced into the OE trigger wire and ran the new wire that to pin 86 on my new 200amp relay. I then ran an earth wire from pin 85. I then took a battery feed from the engine fuse box, added a inline 80amp fuse and connected that to pin 30 and connected the upgraded trigger wire to pin 87. Jumped in the car and pressed the ignition and...absolutely nothing, not even a click of the solenoid. Low battery I thought so I connected up the smart charger. After 6 hours I checked the battery monitor and was horrified to find out the battery voltage had decreased from 12.5 to arround 12v. Realising this must be due to something I had done wrong I reversed the trigger upgrade (disconnected the relay, made safe the live wire etc), fired up the smart charger and hey presto the battery voltage had started to increase.
Cutting to the chase, I had managed to buy a "a normally closed" relay rather than the correct "normally open" relay, the result of which was 12v was applied to the solenoid for 7 hours while on charge!
A this point I am pretty sure the solenoid must have burn out. So I've now booked the car into a local independent to get a new starter fitted and I now have a immobilsed RR blocking the drive way (for the next two weeks) and I'm trying to find a recovery company to pick up the car and take it to the garage.
NEVER LET AN IDIOT (ME) NEAR YOUR CAR!
Phil
[/u]
