![]() | Home > Technical (L322) > Are wheel bearings directional? |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1231 ![]() ![]() ![]() |
I am a marine engineer and fitting bearings all the time, most bearings are not directional, only if for designed for specific fitting / purposes.
PS - Sorry if my above post may sound like 'Teaching Granny to suck eggs' but members spannering / engineering experience varies to a great degree, so if it helps some one, then job done |
Buckie1967 Member Since: 26 Jul 2022 Location: County Durham Posts: 41 ![]() ![]() ![]() |
Thanks, appreciate the input.
Cheers for the video, a wheel bearing incorporating a magnetic reluctor ring, a new one on me, well you don't stop learning till the day you die as the saying goes |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
Just for information, some bearings do have magnetic ring its for the abs sensor pick up it depends on car make. |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 899 ![]() ![]() ![]() |
I don't think so, but it would probably make sense to put on new ABS reluctor rings at the same time
