Home > Technical (L322) > Ride height fault
Mjak42
Australia 2011 Range Rover Vogue 4.4 V8 Santorini Black
Ride height fault
last week we had a fault come up C1A69-1C1C(2Cool cleared it with my Gap scan tool, then 2 days later came up again but different C1A07-62 (AF), (photo) also did live value voltage on height sensors (photo) r/f was much lower than other 3, I ordered 2 new front ride height sensors for front, we fitted both this morning, calibrated ride height and adjusted then checked voltage and was still the same, so probably there is no problem with the sensor at all, we adjusted r/f ride height up 30mm and voltage changed from 1.8 to 2.0v.
When fault comes up car lowers slowly onto bump stops I turn car off restart and then it requests ride height, I raise it to normal height and car is fine, can drive an entire day with no problems another day it will happen 3 times, hasn’t happened whilst towing caravan, am at a loss as to what it could be. 2011 Voque 4.4 TDV8
Post #663553 6th May 2023 6:40am
