Home > Technical (L405) > Range Rover L405 wont start when engine is hot
Steven_Armit
hi there i am having problems with my range rover its a 2013 4.4 sdv8 starts and drives no problem could drive it all day without any issues but once its at temperature and you switch it off when you try to start it it just turns over and doesn't fire up temperature gages sitting just under half way if you leave it half an hour or so to cool down its starts and runs with no problem again until you switch it back off plugged it in no fault codes anybody know where to start looking thanks
Post #663339 3rd May 2023 8:07am
Happy Jim
I had exactly this on a Merc a few years ago, the Crank sensor was the culprit (fine when cool/cold, dead when hot).
I know nothing about RR’s though so might be spurious info for you.
Jim
Post #663365 3rd May 2023 1:37pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Have you had it plugged into a diagnostic machine to see if any codes are stored? If not that would be your starting point. These are complicated beasts and you could waste £1000’s trying to guess the fault.
Jim
Post #663367 3rd May 2023 1:52pm
Steven_Armit
yes plugged it in nothing coming up and the data when running looks fine
Post #663383 3rd May 2023 7:40pm
Steven_Armit
Jim
was thinking down the lines of crank or cam sensor just to see if anybody else has had the same issue and its been something else
Post #663384 3rd May 2023 7:42pm
GraemeS
Monitor the engine rpm during cranking to confirm the status of the crank angle sensor. If no rpm then the crank angle sensor isn't working.
Post #663388 3rd May 2023 8:37pm
Steven_Armit
our snap on machine doesn't seem to give you rpm in the data for some reason al give it another go again tomorrow and see if its in another module
Post #663390 3rd May 2023 8:42pm
