![]() | Home > Maintenance & Mods (L405) > Advise in regards to L405 standing/not started for 3 months |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
If it's getting washed where it sits then the first thing is it will have rusty discs, if the handbrake was left on I suspect that will be rusted up as well.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
what Pete says and also if its under warranty then after the work has been done the dealer should present it back to you in a safe and roadworthy condition... ... - .- -.
CerebralThunder Member Since: 16 Mar 2022 Location: Midlands Posts: 22 ![]() ![]() |
Thanks very much for the replies.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3757 ![]() ![]() |
They were left standing for a lot longer during lockdown - I’d just keep the batteries charged up - we have some diggers and tractors sat for months at a time without issue. If we have concerns we just crank the engine with the electric stop / solenoid on the fuel pump disconnected so that the engine cranks without firing / starting which makes sure oil gets round to the bearings and rings and then reconnect and start as normal. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Maybe ask them to disconnect the battery so it won't get dangerously low/fail... |
RANGER64 Member Since: 04 Jun 2023 Location: Northants Posts: 5 ![]() ![]() |
How hard is the JLR parts situation hitting owners? As a newcomer I knew that new orders were suffering seemingly exponential delays, but a discussion with an underwriter told me that the length of time accident damaged LR products were laid up waiting parts was leading to more cars, and increasingly younger ones, being written off. This was behind the increase in premiums and fewer companies offering cover. At least one major insurer had closed their book to any LR cars under five years old
