Home > Technical (L322) > Traction control kicking in inappropriately
lodelanelad
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
When making sweeping turns or pulling out of junctions with a sharp turn I am getting the sensation that traction control/abs is kicking in and braking my front right wheel. I am not getting any warning lights on the dash...I am not going to be able to get to a garage until the weekend - is there anything I can check on my drive? Has anyone else experienced this? There seem to be a few reports of it happening with alignment/ suspension geometry issues? Thanks
Post #662260 19th Apr 2023 6:53am
dingg1
Started happening to me, then the airbag failed completely on that side, check you don't have a leak on that suspension spring.
Post #662265 19th Apr 2023 9:38am
lodelanelad
It looks level on all corners. I will measure the wheel arch gaps overnight and see if there is any great distance
Post #662267 19th Apr 2023 10:26am
dingg1
Mine was level and not losing air at normal ride height, suggest you raise to highest and lowest setting a few times and listen for the leak. Turn wheels to simulate turning a corner...
Post #662268 19th Apr 2023 10:33am
JayGee
A worn outer CV joint can give a judder/ grabbing sensation in a turn which is a bit like ABS kicking in 2012 TDV8 Vogue (L322)
Post #662341 20th Apr 2023 5:21am
