![]() | Home > Technical (L322) > 2010 to 2012 towbar armature VUB503960 |
JavaBlack Member Since: 07 Sep 2016 Location: UK Posts: 67 ![]() ![]() ![]() |
Have you tried Egdon? https://egdongroup.co.uk |
Peter B Member Since: 26 Aug 2022 Location: Evesham Posts: 31 ![]() ![]() ![]() |
Great idea Java Black, they seem to be quite enthusiastic, so it is booked in with them. Hopefully all will go well. |
Thanks Silver Spanner, I have finally found someone brave enough to turn the bolts the correct way, so see if they can fit it! |
Well, after all that Egdon Land Rover did a fantastic job, even marking the bolts to check for loosening. So at last I have a Range Rover that can tow. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
I fitted my towbar myself on the driveway. I was in for a shock when the manual said 90 minute fitting time - more like 9 hours (doing a few hours here and there).
