Home > Maintenance & Mods (L405) > 4.4 V8 Diesel Suspension type / issue |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
CVD is constant variable dampers. It means the dampers are controlled by a controller that signals to the dampers to adjust their damping behaviour depending on the terrain/road conditions/driving style.
12th Apr 2023 5:49pm |
evotime Member Since: 02 Apr 2021 Location: Aberdeenshire Posts: 134 |
Thanks for that. Most informative X5 40d |
12th Apr 2023 6:03pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2497 |
Rear CVDs have an extra oil chamber attached to the lower part of the shock, facing inwards. Check that both are still attached as they can get knocked off if they've hit something. If one is missing then that shock won't have any oil left so will be totally useless. |
12th Apr 2023 10:47pm |
Thanks for that. Should be an easy enough check. X5 40d |
13th Apr 2023 5:54am |
knwatkins, you were correct X5 40d |
13th Apr 2023 12:41pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
Believe it or not, the oil reservoir canister is actually glued to the shock not welded, go over a bad pot hole and the sudden increase in pressure can just pop the reservoir off...!!! Pete
13th Apr 2023 10:34pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
I note you're from Scotland and thus more rust! Ive changed quite a lot of rear dampers with rot holes in the shocker reservoir... Quite normal... |
13th Apr 2023 10:45pm |
Thanks lads, seems a very poor design.
14th Apr 2023 6:03am |
