Home > General (L460 2022) > P440e Efficiency |
FastLaneJB Member Since: 14 May 2023 Location: Bedfordshire Posts: 17 |
I think it'll need a bigger than a 100kWh battery to get any meaningful range as a full EV. As you say the engine goes but the extra battery is going to make it heavier.
15th May 2023 1:28pm |
d3rm0 Member Since: 12 Feb 2012 Location: UK Posts: 435 |
The EV Hummer weighs 4700kg |
15th May 2023 2:40pm |
Hummer was always heavy, even in ICE form. I think thought as battery density has improved they can get more power in the same weight. So maybe it's possible for instance to do 150kWh now in weight of 100kWh when Tesla released the Model S / X for instance with those battery types.
15th May 2023 3:11pm |
Yousif Member Since: 26 May 2012 Location: Lakes Posts: 36 |
The total range of the P440e is coincidentally around 440miles by my reckoning. That's using the 32.8kw/h battery capacity combined with 70l petrol. I've done a few 240ish mile motorway trips non stop and get around 42mpg indicated but on a longer trip that would drop and its the wrong car for frequent very long journeys. What is very clever is if you use the car's satnav (not CarPlay) in hybrid mode it manages the use of EV juice and always seems to end up at the destination fully used up. |
15th May 2023 5:23pm |
Yes makes sense. The diesel would probably be not far off those numbers on a longer trip and have a longer range but it'll struggle a lot more on shorter trips where the PHEV will shine.
15th May 2023 5:56pm |
RDR Member Since: 05 Sep 2014 Location: Derbyshire Posts: 275 |
Quick update on my experience so far, it seems to be working out as planned for our use case. It’s now got 2400 miles on the clock and I just filled the tank for the second time. Charging is all at home on off peak or renewable. I find EV mode fine but for back lanes and motorways hybrid better so you have the power ready if you need it. Dynamic mode is decent if you’re in the mood. MY23 PHEV HSE
22nd May 2023 7:06pm |
