Home > Technical (L322) > Upper boot hatch slipping down on one side?
lodelanelad
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
Hello
The upper section of my boot hatch seems to be about half an inch lower on one side than the other - any idea which bolt I need to adjust?! Or do I need to take the whole thing off?
Post #661505 10th Apr 2023 3:07pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
i would say the bolts have come loose check which ones might give you some idea to adjust new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #661523 10th Apr 2023 5:16pm
p38arover
Australia
1/2” where? At the top or at the bottom edge when it’s raised?
If the latter, a failing strut maybe? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #661560 11th Apr 2023 3:17am
lodelanelad
When closed it is about half an inch lower on the right hand side....I have found the Powerful UK video for the newer model but the L322 is completely different. I can only see one bolt in each of the top corners and that seems completely rigid with no scope to adjust it. I will post a photo this evening
Post #661573 11th Apr 2023 8:56am
JCW
If it’s the plastic spoiler that’s not even with the roof line across both sides, it may not be properly clipped into all three retaining ‘lugs’. If you loosen / remove the three 10mm bolts from the underside, you should be able to tell if it’s been fitted correctly. Jonathan
2007 Defender 90 XS Hardtop
Post #661583 11th Apr 2023 10:38am
