Home > Technical (L460) > Phone over heats with wireless charging
RDR
Anyone’s phone getting really hot when wireless charging? Mine actually shut down with the over heat message yesterday.
iPhone 12 Pro with genuine apple MagSafe case. Works fine on all other wireless chargers. MY23 PHEV HSE
MY19 Disco 5 HSE - gone
My16 Disco 4 HSE LUXURY - gone
My12 Disco 4 HSE - gone
MY05 Disco 3 S - gone but not forgotten
Post #661394 9th Apr 2023 6:35am
Eirik34
Norway
On the US forum (https://www.rangerovers.net/threads/wirele...st-2395640) they've reported similar issues. Might be related with using Apple Carplay while charging?
Post #661407 9th Apr 2023 9:24am
RDR
Interesting thanks
I wasn’t using car play yesterday when it over heated plus my phone doesnt overheat when using wireless charging and CarPlay in the other cars.
I’ve added it to my snag list for the dealer. MY23 PHEV HSE
Post #661408 9th Apr 2023 9:35am
Crocs
My IPhone has been overheating occasionally as well. But not due to wireless charging as (afraid to admit it) my phone is too old for this technology. Pretty sure it’s something to do with Apple Car Play which I disable now. That also saves data as doesn’t default to Google Maps when there’s a perfectly good navigation system on board.
Post #661422 9th Apr 2023 12:37pm
calicoj
Spain
I'm expecting my L460 in a little over a month, and I have a question: can you disable the wireless charging feature on the L460? If not, can the charging element be removed?
I like the idea of my phone sitting on the hidden shelf where wireless charging happens, but I prefer cable connections when available.
Thanks!
Post #661493 10th Apr 2023 1:19pm
RDR
I haven’t seen an option to disable it. I am using wired to that location now. there is a tunnel to the other compartment you can thread cables from which is much neater than using the connector there. I’m just placing my phone upside down to avoid wireless charging. MY23 PHEV HSE
Post #661512 10th Apr 2023 4:53pm
calicoj
Spain
Thank you for the answer!
I'll have a buddy of mine check mine out when I get the car to determine if it's possible to physically disconnect it from its power supply.
FYI, if you're an iPhone user, you can leave your phone on the charging pad, even if it's already charging via cable. Apple devices have intelligent charging and will use whichever power source was first connected and will ignore the secondary charger.
Thus, if you charge via cable, the iPhone won't activate its internal wireless charging pad and vice-versa.
No clue as to how it works on an Android phone, but iPhone users can use either charging option safely.
Post #661569 11th Apr 2023 9:31am
