Home > Maintenance & Mods (L405) > Deployable steps
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
Deployable steps
So, I jacked up my car as per the instructions in the handbook “the deployable steps must be deployed when jacking up” and have now broken the front mount 🙁 anyone know the part number for the front bracket?
Ta 2017 (67) Vogue SE Corinthian Grey
Post #661379 8th Apr 2023 9:27pm
The steps must be stowed to jack the car up sir... Never jack the car up on a deployed step! The brackets are made of cast aluminium and are made to brake in an impact situation so as to not damage the cars structure... Embarassed
Post #661381 8th Apr 2023 9:33pm
Abacus405
I was following the instructions in the handbook! It was the notes
But was confused, should have read the warning
🤷‍♂️ 2017 (67) Vogue SE Corinthian Grey
Post #661382 8th Apr 2023 9:39pm
Well that's as clear as mud now isn't it... Shocked Shocked Shocked Sniggering Banging Head
Post #661384 8th Apr 2023 9:55pm
For anyone reading this in the future... Look underneath your step and there is a recess for the jack. BUT... Only jack the car up with the steps stowed in the closed position... Thumbs Up
Post #661385 8th Apr 2023 9:58pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Ever so slightly contradictory. As a newbie owner I’m glad I saw this post before attempting to raise my car.
Hope you manage to get the bracket you need 2016 4.4 diesel
Post #661392 9th Apr 2023 4:14am
Abacus405
I’ve sourced one in eBay, I hope it fits 2017 (67) Vogue SE Corinthian Grey
Post #661402 9th Apr 2023 8:02am
I guess it's technically correct - the steps need to be deployed to access the jacking points - although why you'd need to access the jacking points other than to jack up the car isn't clear....
As above, for anyone with deployable steps, you use the built in jacking point that hangs below, with the step stowed -
Post #661405 9th Apr 2023 8:03am
Abacus405
Do the steps just unbolt from the brackets? Or is there a trick to getting them off?
Many thanks 2017 (67) Vogue SE Corinthian Grey
Post #661425 9th Apr 2023 12:10pm
mine are 10mm step to bracket and 13mm bracket to underside of FF.. ... - .- -.
Post #661427 9th Apr 2023 12:30pm
