Home > In Car Electronics (L322) > remove multi changer
pretlove
any idea how to do this as ive looked and to me it seems almost all the dash needs to come off just to do it...so if anyone knows how please tell me before i pull my car to pieces Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #71833 9th Jul 2011 8:33pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Sadly you do, but it's not actually as involved as you'd think.
SteveGT helped me when I ffitted my ACM. In a nutshell, remove all the torx screws on the top, remove the speaker grille and the screws it reveals. Remove the air vents and take out 1 screw on each side.Then slide the dash top towards you and then lift it up. (if you leave the dash speakers in you need to be a little careful when you disconnect the cable)
http://topix.landrover.jlrext.com/topix/co...p;id=61933
If that doesn't work.
http://topix.landrover.jlrext.com/topix/vehicle/lookupForm and browse for your vehicle new range rover etc.
Click Owner on the top right and select accessory fitting instructions: ICE/ entertainment.
Post #71836 9th Jul 2011 8:49pm
pretlove
so as if i was fitting my stereo again lol oh well i might as well do the reverse cam at the same time thanks matt Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #71855 9th Jul 2011 11:30pm
speedymarktd6
another thing to remember is when the changer is disconected all functions on the media display thing in the middle will cease to work full stop or they did in mine when i was fitting the acm as the stereo system has to see that the changer is there by comunication to and from so when its removed it all throws a wobly.
it might not effect early cars but just so your aware Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #71861 10th Jul 2011 4:30am
pretlove
ive changed my stereo anyway so no longer have a use for the multi changer Thumbs Up but thanks for the heads up "RANGEISM WILL NOT BE TOLERATED"
Post #71863 10th Jul 2011 6:41am
