How much free play in the transfer box is normal | |
Hi All,
I am still trying to track down why I get a thump in the drive train when I first select Drive or Reverse.
I jacked up one rear wheel and there is about 20 degrees of slack. The prop rotates in sync with the wheel so it is in the transfer box or the gearbox.
Is this amount of movement normal ?
In the photos you can see the amount of movement from the position of the Pirelli name on the tire.
Cheers
 | Click image to enlarge |
 | Click image to enlarge | 2016 AB SDV8 Barolo black
