Home > Technical (L405) > Issue resolved - Are lower rear window trims removable?
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Hi
Are lower rear window trims removable or are they part of the rear window? I need to remove mine to repair some clear coat
Regards
Mark
 L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone
and lots of other none LR stuff…..
Post #660047 22nd Mar 2023 4:58pm
nambFFRR
I’ve found out the trim is integral to the rear window.
Regards
Mark L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #660137 23rd Mar 2023 4:03pm
thanks for the update Mark.. Thumbs Up ... - .- -.
Post #660141 23rd Mar 2023 4:32pm
JavaBlack
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
You need some of this, plastic side under the rubber, sticky side to the glass.
Post #660143 23rd Mar 2023 4:41pm
nambFFRR
Thanks for this…..I’m talking to the smart repairer so I’ll ask what he suggests. Ideally I don’t want to remove the rear window to effect the clear coat repair L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #660181 23rd Mar 2023 9:29pm
