Home > Maintenance & Mods (L322) > 4.4v8 fan roaring permanently |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8285 |
First off, as you have found, don't just change things when a fault code appears, 95% of the time it is not the item that has failed but the fault system itself....
22nd Mar 2023 1:52pm |
Geoff West Member Since: 26 Apr 2020 Location: Bangor Co.Down Posts: 8 |
Thanks Hayland I'll try that (and update my profile ta) |
22nd Mar 2023 3:22pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1479 |
Please stop using your current garage and replacing parts willy nilly - they clearly like to cash in (sorry, but it's true).
22nd Mar 2023 6:34pm |
The car always goes to an independent LR specialist, and they are very good. Problem is they are in such demand that there's a 10 week wait for an appointment. So in the meantime I ordered the fan and wing mirror on Ebay and was convinced that would cure the problem, but it's obviously some other problem, likely electrical.
22nd Mar 2023 8:50pm |
Sounds like it could be poorly fitted multiplugs after previous repairs?
22nd Mar 2023 8:54pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2501 |
I would check all power and earth connections in the vicinity of the battery. |
22nd Mar 2023 9:05pm |
Thanks, I'll check the multiplugs and connections around the battery area but tbh I'm not hopeful. The lack of throttle response when selecting 'Drive', but only when cold, has me completely baffled. It's a pain waiting five minutes for engine/transmission to warm up before you can go anywhere, especially when you're running late!
22nd Mar 2023 9:27pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Try doing a Hard reset & see if that brings back the original settings. |
23rd Mar 2023 10:08am |
Thanks Highlander, tried that but no difference |
23rd Mar 2023 11:25am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3258 |
It would be wise to invest in a GAP IID tool so you can do proper diagnostics. It will pay for itself very quickly and can be sold for a near new price if you move on from JLR ownership. Most here wouldn't contemplate L322 ownership without one... 2012 TDV8 Vogue (L322) |
23rd Mar 2023 11:31am |
Thanks Jaygee, i've been thinking that. Would a generic one do the job, or would it have to specific to RR? Any recommendations ( at a reasonable price)? |
23rd Mar 2023 11:50am |
The GAP IID bluetooth is by a large margin the preferred device and will do a lot more than a generic code reader.
23rd Mar 2023 11:59am |
Thank you, appreciated |
23rd Mar 2023 12:27pm |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 |
With regard to Cooling Fans, I found that a lot of Jaguar and Landrover parts interchange, and in the Ford era, Ford parts. Key Modules have Volvo stamps for instance. I had, some years ago a full speed fan on a Jaguar V12, and found, upon dismantling the fan motors and resistor pack that the resistor pack was heavily corroded, and fell apart. So its worth disconnecting the fan multiplug, and check the resistances and whether you are continuously drawing full power. A stuck Air Con relay can do the same, but its also worth doing a diagnostics check just in case, but often faults at the front of any vehicle are corrosion somewhere. |
23rd Mar 2023 12:33pm |
