Home > In Car Electronics (L322) > Radio turns off when car not running
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
If the car's engine is off, the radio only runs whilst the ignition is on (ie: foot off brake, press start/stop button to enable ignition).
For me it only works for about 10 mins (max) then it'll shutdown, I think with the message "low battery power", though as far as I can tell the battery isn't particularly low.
(My battery isn't particularly strong right now, but it's also not bad and I believe it did this with a fresh battery installed too)
Does anyone know what the threshold is for cutout?
Does anyone know what senses this or if it can be calibrated?
I'd like to 'fix' this so I can run the radio for as long as I want, running the battery down isn't such a worry now I have the second battery fitted.
(2011 TDV8)
Post #659896 20th Mar 2023 4:39pm
this is normal and i dont think time out can be altered.. ... - .- -.
Post #659901 20th Mar 2023 5:25pm
Siftah
Googling, it looks like it's a common thing for all Range Rovers (Sport, Evoque etc). How annoying!
Even with the CTEK set to supply mode it turns off, so it must be a timer rather than being voltage related, that's significantly harder to fix Sad
Post #659921 20th Mar 2023 7:51pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Annoying isn’t it - I couldn’t find a way to resolve it but would be interested if anyone has.
Post #659922 20th Mar 2023 7:55pm
Siftah
I think I've realised why RR owners have such a bad reputation for being sat there with the engine running, it's so we can listen to the radio Rolling with laughter
Apparently we love music more than the environment, who knew!? Whistle
Post #659926 20th Mar 2023 8:33pm
Weegie
The radio should stay on with the ignition in position 1. It goes off by design on a timer if the ignition is completely switched off. John
GAP iiD BT-Sold
Post #659936 20th Mar 2023 10:11pm
V8 Bob
On the last models with no ignition key the radio goes off as soon as the engine is stopped by pressing the start button. There is no position 1 the only option is to press the starter without pressing the brake and having the full ignition on. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #659940 21st Mar 2023 12:38am
Weegie
Understood. Thumbs Up John
GAP iiD BT-Sold
Post #659950 21st Mar 2023 8:26am
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
Siftah wrote:
How annoying!(
Not really - better than a flat battery & most RR sound systems can soon take the best out of a good fuly charged battery without the engine running.
Post #659970 21st Mar 2023 1:26pm
Siftah
Perhaps, but I have two batteries installed and 300watts of solar panel on the roof, so I can keep the stereo running without any issues!
The RR has a battery voltage sensor, so it could easily just shut itself down if/when the battery voltage sags, the usage of an arbritary time limit is pretty annoying IMHO Sad
Post #663304 2nd May 2023 6:39pm
