Home > Maintenance & Mods (L322) > 2007 front speakers XQM 500170
Soldierpmr
Wales 2007 Range Rover Vogue TDV8 Zermatt Silver
The driver side door speaker blew a good while ago. Now the front passenger has started to create the flap noise. My question is do I need to replace them like for like with part number XQM 500170 or is there an alternative out there that can be used?
Post #659510 15th Mar 2023 9:28pm
Pawl
Beware Land Rover speakers are often 2 ohm, whereas most aftermarket are 4 or 8 ohm.
Also typical OE speakers have more sensitivity - ie every Watt from the radio generates more noise.
If the relevant values aren't matched, a replacement speaker will be much quieter and often not audible - unless all speakers are changed together. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #659514 15th Mar 2023 10:06pm
Soldierpmr
Thanks for the info. Is there a way of finding out what the Ohm of the original is?
Post #659518 15th Mar 2023 10:36pm
Pawl
I think the ohms are in the Workshop Manual.
Sensitivity won't be. I'm not sure if it's on the speaker labels Paul,
Post #659519 15th Mar 2023 10:40pm
garyRR
I've replaced loads now - really common for the low ranges to experience coil rub. They're XQM500170 (now replaced by XQM500420). They're about £50 each from main dealer.
I'm aware of only one retrofit part which is the GAS PS3M62 PRO SPL. You'll need to get them imported from Norway however. They're about €100 for a pair, plus shipping, plus VAT. They are apparently significantly better quality than the Harmon Kardon speakers.
You can actually replace these speakers without needing to remove the whole door card. Just remove the door card screws and pop off the lower trim clips and flex out the door card a bit and there's enough space to fit a small T20 Screwdriver inside to swap the speakers over. Takes about 5 minutes per door. There's 5 screws and 1 multiplug on the side of the speaker. 2015 Range Rover Autobiography 4.4 SDV8
Post #659531 16th Mar 2023 9:02am
Soldierpmr
Thank you for the answers.
Post #659568 16th Mar 2023 5:07pm
rryan
United Kingdom 2010 Range Rover Vogue TDV8 Buckingham Blue
Hi all,
Sorry to be that guy and resurrect an old thread, poor form.. I know!
My passenger side has also now gone crackly and I wondered if the XQM500170 is interchangeable with the newer XQM500420? I've been shopping around (money's being spent on more important mechanicals first!) and seen a fair few used -170s as opposed to the OEM -420.
Thanks in advance. I'll start a new thread if this is fully closed Thumbs Up
Ryan
Post #686536 26th Feb 2024 9:18pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
according to JLR yes and they are having a 20% sale too
 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #686996 2nd Mar 2024 7:17pm
