![]() | Home > Technical (L405) > Todays heath check. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1395 ![]() ![]() ![]() |
The brake pad warning light should come on at 2mm, and even at that one has quite a few miles in hand before there is any risk of the pads damaging the discs. Sorry I don't know enough to comment re the oil leaks. Only Range Rovers since 1988 |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1156 ![]() ![]() ![]() |
Thx cs.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1273 ![]() ![]() |
Has this been done on your vehicle? https://www.fullfatrr.com/gallery/albums/userpics/10080/N357.pdf Read this has the oil leak at the turbo could be tracking to the actuator. https://www.fullfatrr.com/forum/topic57501.html 2018 SE SDV8 4.4 Byron Blue |
Thanks Kot.
Yes it needs doing.
Hi Kot
