Home > Technical (L405) > Locking Issue L405 2014.
Don Henshall
United Kingdom 2014 Range Rover Autobiography SDV8 Carpathian Grey
On pressing the key to lock my RR (2014 RR Autobiography 4.4) I would get the beep, beep sound but the mirrors would not fold in. This would happen intermediately, though on checking
the drivers door it was locked. When I tried the O/S rear door it opened and the alarm sounded?
On turning the alarm off I tried again and the car locked normally.
This happens intermittently.
I do have a full RR warranty but not sure if electrical issues are covered.
The car has been serviced by a MD since new. Now showing 52K.
Any ideas as to what the fault might be would be appreciated. 718 GT4
FFRR AB
BMW R1250RT
Honda ST 1100
Sold
Freelander 2
Porsche C4S Cab
D4
BMW 520 M Sport Touring
BMW R1200RT
BMW R1150RT
MX5 2lt Roadster
Post #659202 12th Mar 2023 3:43pm
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
Just to clarify, is the double beep the one that goes with the indicator flashes to show it is double locked or the double beep (quieter ones) indicating unable to lock. Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #659203 12th Mar 2023 4:04pm
Don Henshall
The quieter ones. 718 GT4
FFRR AB
BMW R1250RT
Honda ST 1100
Sold
Freelander 2
Porsche C4S Cab
D4
BMW R1200RT
BMW R1150RT
MX5 2lt Roadster
Post #659205 12th Mar 2023 4:23pm
V8 Bob
Failure to central lock is usually caused by doors not shut properly. This could either be a lock slightly out of line or an electronic fault giving a false message that a door is not shut properly.
Focus on the rear door that is not locking does it shut ok? I would guess that the electronic signal is given by the light switch. Do you get an open door message when ignition is on? Does the fault only occur after the door has been used? 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #659212 12th Mar 2023 4:40pm
MrWold
So something is preventing it locking? Doors/tailgate/bonnet not fully closed? My sport bonnet needed a good slam down even though apparently fully closed otherwise it wouldn't lock. Chris
1990 Citroen BX GTi
1973 Triumph GT6
Post #659214 12th Mar 2023 4:41pm
Don Henshall
Ok, after several experiments I believe it’s the tailgate door that is the problem. She has just come back from her annual service and it sounds like it needs some lubrication on the struts or something like that which might be impeding it from fully closing as the lower half is definitely soft closing but the upper part not so.
Guess I’ll pop back to my dealer and get them to check it out.
Thanks guys, your assistance is very much appreciated. 718 GT4
FFRR AB
BMW R1250RT
Honda ST 1100
Sold
Freelander 2
Porsche C4S Cab
D4
BMW R1200RT
BMW R1150RT
MX5 2lt Roadster
Post #659217 12th Mar 2023 5:13pm
Mollyhetherington
United Kingdom 2013 Range Rover SDV8 Causeway Grey
Mine doing exactly this now. Just wondering if you managed to get to the bottom of it and how to fix please?
Thanks!
Post #686840 29th Feb 2024 11:38pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I have had this three times. Each time required a new door lock actuator to repair. One door left until I have a full set! Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #686897 1st Mar 2024 4:08pm
