Home > Technical (L322) > Connection - water outlet parts needed
Alinton
Ireland 2011 Range Rover Vogue TDV8 Zambezi Silver
Hi, does anyone have a source for these two parts please? Dealers here (Spain) seem out of stock.
Both are labelled Connection - Water Outlet, part numbers:
LR022690LR
LR110459LR
Thank you.
Andy
[/img]
Post #658768 7th Mar 2023 3:47pm
JayGee
They are out of stock everywhere - what part has broken as repairs are possible ( and likley your only option ) 2012 TDV8 Vogue (L322)
Post #658769 7th Mar 2023 3:49pm
Alinton
Both cracked when being removed to find an oil leak. How are they repaired? Epoxy resin maybe?
Post #658771 7th Mar 2023 3:50pm
JayGee
If it's the outlet and inlet connectors/ tubes they can be sleeved with aluminium and glued with rubber impregnated cyanoacrylate but if the body of the units are cracked I'd not rely on glue alone. Unfortunately the plastic on these has become weak and brittle with age. The other option is to source used parts from newer L405 SDV8 engines which are less likley to have age related weakening. 2012 TDV8 Vogue (L322)
Post #658777 7th Mar 2023 4:22pm
Alinton
Are the L405 parts directly compatible?
Post #658778 7th Mar 2023 4:24pm
JayGee
Yes. 2012 TDV8 Vogue (L322)
Post #658780 7th Mar 2023 4:29pm
