![]() | Home > Technical (L405) > Fuel flap release not working |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1273 ![]() ![]() |
I dont believe there is a manual release.
blackbeltbob Member Since: 06 Oct 2022 Location: Ayrshire Posts: 32 ![]() ![]() ![]() |
Thanks.
Wrecker79 Member Since: 15 May 2014 Location: Reading Posts: 85 ![]() ![]() ![]() |
Looking at the workshop manual, there appear to be a cable between the actuator motor and the pin that should pull back to release the flap - and in the picture (item 4) there is a small extension cable with a pull on it that should effect manual release - pull down the boot liner and have a look.....
Awesome, thanks.
So a wee update.
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 501 ![]() ![]() ![]() |
Glad you got it identified and on the road to being fixed. Jolly annoying that small component failure can temporarily scupper the fun. First time FFRR owner |
Totally agree. I’m trying to ignore the fact a £125k ish car has such a daft failure at nearly 5 years old. Crazy.
If it makes you feel better, we have a constant stream of < 3 year old vehicles with similar failures on the BEV charge port covers, the RAC 'helpfully' remove the painted covers so the vehicles can still be charged whilst they wait for the required parts which are on constant backorder, the cover has, of course, to be painted - despite there being a non-damaging way of releasing the cover... |
That does. Thanks.
The thing about 'expensive' cars is the majority of the engineering is spent on fit, finish & NVH - the sort of stuff you'd notice every day. Powertrain/Drivetrain is usually an evolution so not really a 'cost' as such, electrics & control systems are much the same - sometimes planned two or three MY's in advance.
Yep I remember the days of fuel locking caps |
Thank god it’s not a Ford Focus!
