Home > Technical (L405) > L405 3.0 SDV6 no hot air from heater |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1400 |
is it cold all the time even if you set the heater to max temp and low fan speed ? V8 or else ... |
7th Mar 2023 1:05pm |
rsdave137 Member Since: 14 Jul 2020 Location: lancashire Posts: 4 |
Hi,
7th Mar 2023 7:54pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3184 |
either the aircon compressor valve is stuck (replace whole compressor, it's as cheap as just the valve I hear) or it may just be the Heater Control Valve-Duokon Heater Control Valve, ABS Heater Control Valve Fit for LR016848.
7th Mar 2023 8:10pm |
