Home > Technical (L322) > 2007 TDV8 - Trailer electrics different to TD6?
Scouse Exile
Hi,
I found this thread which if I’m reading correctly seems to suggest that the OEM tow bar electrics loom is different on 2007 TDV8 to the earlier TD6 models.
https://www.fullfatrr.com/forum/topic59542.html?highlight=13+pin
I’ve fitted a Westfalia eBay special which I’m fairly sure came off an earlier car but I think the loom is wired wrong for my year of vehicle. I’ve tried testing the pins (13 pin type) and it seems a bit all over the place.
Anyone know if the loom is indeed different on the two models?
Jon
Post #657787 25th Feb 2023 7:05pm
Scouse Exile
If it helps, this is the control box that came attached to the loom I got with the tow bar;
Post #657878 26th Feb 2023 7:21pm
Scouse Exile
And this is the loom type - part nr YMZ000020
From what I can work out it should fit models to 2009 but the link I referenced in the first post would suggest otherwise. A quick google of that part number brought up this - https://parts.jaguarlandroverclassic.com/y...1FD180115C
Anyone got some wise words? I’m confused 🤯
J
Post #657930 26th Feb 2023 11:42pm
Scouse Exile
Thought I’d bump this thread in case anyone can help.
Jon
Post #689179 28th Mar 2024 12:39am
Scouse Exile
Bumping this again in the hope someone can assist.
To simplify the question: can someone with a TDV8 of circa 2007/2008 vintage tell what the part number is for their loom/control module (the white box of black magic that plugs into the car).
Anyone??
J 🙂
Post #693646 30th May 2024 5:54pm
Scouse Exile
One last try ............ Anyone got a 2007 era TDV8 with a Westfalia tow bar fitted could you send me a picture of the Siemens box part number please?
Thanks
Post #694225 10th Jun 2024 6:31pm
