Home > Technical (L322) > Restricted performance Gearbox |
Triumph72 Member Since: 11 Apr 2018 Location: Argyll Posts: 39 |
I had some remedial work to do on my car after an MOT fail, I renewed both lower control
23rd Feb 2023 1:41pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8235 |
Have you got odd sized tyres across an axle or have you changed the tyre size in the IID settings..? Pete
23rd Feb 2023 2:13pm |
Hi
23rd Feb 2023 2:26pm |
OK, I had that fault code on my old Rangie.. those two reasons can set that fault...
23rd Feb 2023 2:59pm |
Had a play with the iid and found the wheel speeds in the abs module, they are all reading correctly.
23rd Feb 2023 3:31pm |
Screen grab all the codes, clear them and keep your fingers crossed...
23rd Feb 2023 3:48pm |
The car is still doing it, driving along car loses drive revs rise and if you rev it up there is a screeching
24th Feb 2023 11:55am |
Just an update, this turned out to be the transfer case and
31st Mar 2023 9:06pm |
Glad you got it fixed... Pete
31st Mar 2023 9:20pm |
