From the W/M, toe can be adjusted at the rear...
TIE ARM
The tie arm is pressed steel with both ends having a bush pressed into an
integral housing.
The inner bush locates between brackets on the subframe and is secured
with a special eccentric bolt, washer and nut. This allows for the adjustment
of the rear wheel toe. Rotation of the bolt moves the eccentric head within
a recessed slot in the bracket, allowing the toe to be adjusted within the set
limits. The outer bush attaches to the wheel knuckle. Pete
