Home > Maintenance & Mods (L405) > Slow intermittent change of 1st 2nd 3rd gears when cold
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys been experiencing this for a few months now changed gearbox oil and transfer case oil and still the same slow gear box changes 1st 2nd 3rd only when cold but must add it’s intermittent when cold also. Also when cold if I give it some throttle there’s a sudden jolt pull back like a flat spot then pulls away only when cold and intermittent.When I give it some throttle when warm peddle down to floor you can really feel the downshift from gearbox is this normal also.
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #656203 10th Feb 2023 12:46pm
M11buc
United Kingdom 2019 Range Rover Autobiography SDV8 Santorini Black
I also have found this. Ok when hot but 1st gear when cold first setting off very light throttle, jerks into gear. I have also changed auto box oil. Made no difference. I have read you can reset gearbox data/ settings, not done this as heard when others have done this it has made made thing worse. Mine also has no fault codes stored for auto box and no warnings come on dash.I only noticed it starting to do this around 2 months ago, before then it was as smooth as silk.
So if any one know any thing I would be interested to find out
Post #656234 10th Feb 2023 7:11pm
jaysta10k
In all honesty Im starting to wish I never bought this car I much preferred the L322 all I’m hearing is issue after issue online about this model why put a chocolate gearbox into an off-road vehicle AGAIN I would of thought it would of improved dramatically since L322 as it had its fair share of problems as we all know… I’m hoping I can get this issue rectified in some way if anyone knows anything about this gearbox issue!
Cheers
Previous Cars
BMW M3 Carbon Black
Post #656242 10th Feb 2023 8:50pm
