Home > Technical (L322) > T91 Telestart Remote(FOB) Pairing
s.ozer1991
Turkey 2010 Range Rover Vogue TDV8 Nara Bronze
Hi Dear Friends
I have 2010 Range Rover 3.6 TDV8. The car has Telestart module on right rear of car(view 1). But i hadn’t haven remote(fob) of it. I watched a video about fob on youtube(URL 1). And I bought a remote on ebay(View 2).
When i want to pair telestart module and fob, i couldn’t do it. I applied same steps on video. I remove socket from telestart module, i waited at least 5 seconds. And then i plug in and i pressed off button of fob within 5 seconds. But i didn’t work. Fob blinks 5-6 times. It didn’t blinked once.
Where is problem? Could you help me about solving issue.
Thank you!
View 1:
URL 1:
[url] [/url]
View 2:
Details of fob:
GJ3218D539-AA
9027438A
18615
Post #656128 9th Feb 2023 3:14pm
Phoenix
That's the wrong remote, you need the one with on and off buttons, not off & pictogram
Post #656131 9th Feb 2023 3:42pm
s.ozer1991
Thank you for your answer.
In this video, the guy says that two remotes are actually same and only differency is visualizaon of on button.
If somebody has remote,which has on-off button, can send a photo or information of backside of battery? There is a part of code block there.
Post #656132 9th Feb 2023 3:47pm
mjdronfield
https://www.fullfatrr.com/gallery/albums/u...rt-t91.pdf
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #656136 9th Feb 2023 4:16pm
mjdronfield
https://www.fullfatrr.com/forum/topic47265.html
Some others had same issue. As above, you have the wrong remote. You need one that says ON and OFF. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #656138 9th Feb 2023 4:26pm
s.ozer1991
Thank you for pdf.
I was looking for along 2 weeks, i couldn’t find that kind of detailed document.
I hope it can help me.
Post #656139 9th Feb 2023 4:26pm
s.ozer1991
Thank you for both of you.
As i ınderstood i have to change my remote.
Thank you for your helps and times.
Regards.
Post #656140 9th Feb 2023 4:35pm
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
This is the remote you need not the t91r
Post #656166 9th Feb 2023 10:44pm
s.ozer1991
thaknks for replying.
I will be in Germany for along 2 weeks.
Do you know any website for able to buy this remote? Also used products can be more effective for me.
Post #656173 10th Feb 2023 4:35am
KF
Finland 2007 Range Rover Vogue TDV8 Stornoway Grey
German ebay is a good place to start with when in need for Webasto-stuff.
Post #656182 10th Feb 2023 8:46am
