Home > Technical (L460) > Cabin Pre-Conditioning
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
I don’t have this on my First Edition but it’s coming on my new SV which is due to be built in a few weeks. The description states that you can now pre heat and pre cool without switching the engine on. Does anybody know how this work? The previous FBH only ‘vented’ when in the cooling function so I’m intrigued how it works.
Does the conditioning now integrate into the app too?
Post #655375 1st Feb 2023 6:28pm
Martin2
Is it a hybrid? MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #655378 1st Feb 2023 6:49pm
Autobiography
Nope. P530. This is what it says on the configurator:
Your journey begins when you want it to and how you want it to. Pre-heat or pre-cool the cabin from your phone, without starting the engine or getting in the vehicle.
Post #655383 1st Feb 2023 6:59pm
Martin2
Maybe it's the wording then as you don't start the car, but it remote starts it from the app?
Mine does the same, you can heat and cool from the app, but the engine is fired up. MY23 Panamera E-Hybrid
Post #655387 1st Feb 2023 7:07pm
5.0
On my build sheet it says Fuel burning cabin preconditioning with remote control. So I was just assuming it was the same set up as with the L405 (a separate remote). I would be surprised if it actually cools other than by just turning the fan on and opening the vents. It would be great if it did cool though, I would actually find that more useful than the heating.
Post #655393 1st Feb 2023 7:30pm
Martin2
Mine has the FBH with remote, I use that to heat the car then the app to remote start and cool in the summer. MY23 Panamera E-Hybrid
Post #655414 1st Feb 2023 11:01pm
5.0
Yes, I understand that's how it works. I was meaning it would be good if it cooled without the engine on because having the engine running is not desirable for a number of reasons.
Post #655421 2nd Feb 2023 9:40am
Phil.
I don’t think you can cool any car without aircon on which means having the engine on. The FBH on cool only recycles the air inside-outside. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #655426 2nd Feb 2023 1:38pm
Martin2
Yes, you can only do it on hybrids and EVs as they use the battery to run the aircon MY23 Panamera E-Hybrid
Post #655473 2nd Feb 2023 11:06pm
