Home > Technical (L405) > Part Numbers
e600
United Kingdom 2006 Range Rover Vogue 4.4 V8 Zermatt Silver
Part Numbers
My front left door lock started playing up, in as much as say 1 in 20 opens from the passenger seat wont work. It has always opened from outside. I suspect the issue is the lock.
Rather than wait for it to fail completely I decided to change it whilst it still works having seen on youtube the problems of trying to open the door if it fails completely.
I contacted my local main dealer, Guildford, who wouldn't give me the part number.
Is there a source to obtain part numbers other than JLR main agents.
The car is a 4.4 AB 2013 with keyless and soft close options.
TIA
Post #655356 1st Feb 2023 3:27pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I use this dealer to look up part numbers and order from. There is the same in the UK and others will chime in.
I also get parts from EBay.
https://landrover.lakeridgeparts.com/a/Lan...06555.html Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #655359 1st Feb 2023 3:38pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Re: Part Numbers
TIA
I use the following as the part numbers seem to be updated more frequently than some other sources :-
https://store.landrover.com/parts/index/hi...and-rover/ L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #655367 1st Feb 2023 4:42pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
This is always a good start as well
https://www.scuderiacarparts.com/en-gb/car...s_463.html
Post #655382 1st Feb 2023 5:58pm
