Home > Technical (L322) > 4 wheel alignment around exeter area |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3255 |
Search Google Maps for 'Hunter' equipped garages. Be aware that the adjusters can become seriously corroded and seized therefore the garage may not be able to do any adjustment. 2012 TDV8 Vogue (L322) |
27th Jan 2023 5:00pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Look up a Hunter place on www.alignmycar.co.uk
27th Jan 2023 7:49pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3166 |
If you come up near Bristol at all I used an excellent bunch (Latvian Or Lithuanian)
27th Jan 2023 10:49pm |
bastion Member Since: 17 Oct 2018 Location: uk Posts: 26 |
There are not very many Hunter machine locally but some do use SUN PRISM Machine made by Snap On with the latest John Bean software.
11th Mar 2023 1:53pm |
damonky Member Since: 24 Apr 2018 Location: Devon Posts: 19 |
I had mine done at bp tyres near newton abbot about a month ago on a hunter setup. https://bptyres.co.uk/ -----------------------------------
17th Mar 2023 6:31pm |
Just went to Marsh Tyres Exeter to get the alignment done, was told oh no you need four new tyres to do the test.
14th Jun 2023 3:21pm |
Glibbs Member Since: 18 Aug 2019 Location: West Somerset Posts: 112 |
Devon 4x4 did an excellent job on mine. Range Rover 4.2 SC
14th Jun 2023 3:40pm |
You don't need 4 new tyres. Just try Halfords or Kwickfit if you need it checked. 2012 TDV8 Vogue (L322) |
14th Jun 2023 3:43pm |
Worth going to someone good like devon 4x4 or bptyres. Went to get mine checked at national after replacing the front shocks. 3 attempts and it drove itself in circles. Back on a hunter rig and it was miles out. -----------------------------------
14th Jun 2023 4:44pm |
Kwickfit used Hunter last time I had mine done (just front toe after track rod replacement). Often though it's not the kit the garage has but the ability and knowledge of the person operating it. 2012 TDV8 Vogue (L322) |
14th Jun 2023 5:22pm |
Very true. Hence i’ve found both the above to be very good. Should’ve read the warning sign that the office was full of monster cans at national 😂 -----------------------------------
14th Jun 2023 5:30pm |
Had the tracking done at bptyres. Very good service, but car is still pulling to the left.
15th Jun 2023 3:50pm |
Not a massive expert, but could be 1 of the following perhaps that I've had in the past with this and other cars / vans:
15th Jun 2023 4:08pm |
Thanks for the thoughts5.
15th Jun 2023 4:59pm |
