Home > Maintenance & Mods (L322) > What coolant for L405
Don Henshall
United Kingdom 2014 Range Rover Autobiography SDV8 Carpathian Grey
Recently had to top up me coolant. £17 from LR?
What coolant do you use and where is the best price to be found?
In my 5 years of ownership this is the first time I’ve had to top her up so hopefully no the result of any leaks. 718 GT4
FFRR AB
BMW R1250RT
Honda ST 1100
Sold
Freelander 2
Porsche C4S Cab
D4
BMW 520 M Sport Touring
BMW R1200RT
BMW R1150RT
MX5 2lt Roadster
Post #654656 25th Jan 2023 7:55am
JayGee
Probably best to post this in the L405 forum but the 4.4 engines are essentially the same as the L322. The coolant type is in your handbook. Any coolant loss is not normal so should be investigated without delay. 2012 TDV8 Vogue (L322)
Post #654663 25th Jan 2023 10:17am
Phoenix
It's normal for coolant levels to be topped up on service, the compacted graphite /iron blocks used in the 'Lion' series engines and others, do allow coolant to be 'consumed', Its quite normal to add 500-800ml at service time, obviously if you're having to top it up between services or add significantly more, then there is an issue to be investigated.
Post #654689 25th Jan 2023 3:32pm
JayGee
I didn't realise that - thanks for the info. 2012 TDV8 Vogue (L322)
Post #654690 25th Jan 2023 3:58pm
