![]() | Home > Technical (L322) > L322 Central Locking |
tony66 Member Since: 01 Dec 2014 Location: fife Posts: 92 ![]() ![]() ![]() |
i wouldnt buy anything until you explore what is going on inside the door tbh,could be a clip or anything... |
ricky25 Member Since: 18 Dec 2018 Location: Leicester Posts: 18 ![]() ![]() ![]() |
Thank you for such a prompt reply. I'm a bit reluctant, however (as an amateur) to strip the whole door panel down then potentially have a time lag before I can reassemble it and use my vehicle again. |
annette Member Since: 07 Nov 2018 Location: Tilarán Posts: 30 ![]() ![]() |
Don't worry you can drive it with the panel off, we do it all the time when testing client's cars.
Very helpful - thank you ! |
Is it necessary to disconnect the battery first to "protect" the door airbag ? |
only if you want to disconnect it...if not you could pull the fuse/s thats what i used to do on my e53 x5[similar systems] |
LASBAM Member Since: 04 Apr 2017 Location: Reutlingen Posts: 26 ![]() ![]() ![]() |
Hello together,
