![]() | Home > Technical (L322) > Steering angle/trans/HDC/progs/suspension lowered cascade |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2653 ![]() ![]() |
Calibrating the e-diff is available on the IIDtool. |
RogerL322 Member Since: 12 Aug 2022 Location: Worcester Posts: 15 ![]() ![]() ![]() |
GraemeS, I can see a calibration function for the transfer box clutch, but not the rear diff, or am I missing something? Range Rover Vogue SE L322 3.6TDV8 2008 |
I'll check shortly, but IIRC the function was added at my request a few years ago as I needed it after installing an e-diff with a control unit out of a D4.
GraemeS,I do have the self test. Unfortunately it just finds the same errors rather than trying to recalibrate or reset. Thanks for the advice though... multiple self test can sometimes unstick something that's stuck after all. In this case, no joy. Going to take the connector off and thoroughly clean. Then if no joy, the motor and if necessary redo bushes etc. Then finally, if that don't work, spend £165 of many hard earned cash on a new unit and hope that OEM means just that. Range Rover Vogue SE L322 3.6TDV8 2008 |
