Home > Technical (L322) > 2003 td6 transport mode
Wk52RR
England 2003 Range Rover HSE Td6 Epsom Green
Hi all,
Car was in my barn having some work done for the mot which turned in to a months worth of work. When I but it in the barn I left it in neutral with the key in as the only way to get in the barn and then be able to get out the car is by pushing it the last little bit.
Completely forgot about this in eagerness to do the work on it.
Long story short the car went completely flat not enough power to power an led interior light.
Put the battery on charge and everything seemed normal on the car except none of the interior lights work apart from the two on the upper tailgate and the central locking doesn’t work from the main button under the hazard switch or from the key.
Fault code reader says the car is in transport mode. However from what I’ve read the wipers shouldn’t work and neither should the air suspension. This all works perfectly just the fault that won’t clear and no interior lights or locking ability.
Post #653381 12th Jan 2023 5:43pm
