Home > Technical (L405) > L405 Rear Door Won’t Open
samb096
Evening, my drivers side rear door won’t unlock. Went out for a walk and came back and only the 3 doors and boot would unlock. If I pull the handle the side step pops out but the door remains locked. When I press the unlock button inside the LED indicator light doesn’t switch over to show it unlocked either. Is there a way of manually unlocking the door so I can get it open to remove the door card and take a look? TIA.
Post #653085 9th Jan 2023 5:31pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Try pressing the child lock button on the drivers door to cycle the door locks on/off. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #653187 10th Jan 2023 3:31pm
Kot
Re: L405 Rear Door Won’t Open
Try the search button, download the WSM in the Wiki, check for DTC's
https://www.fullfatrr.com/forum/topic48618...oor+unlock 2018 SE SDV8 4.4 Byron Blue
Post #653193 10th Jan 2023 3:58pm
johnf
2013 Range Rover Autobiography 5.0 SC V8 Bonatti Grey
I had this a few months ago. On mine it was a fault with the soft close mechanism. Dealer was able to get the door open and replace the faulty part. I had visions of needing to cut through the door card (as some googling suggests might be necessary) so pleased to discover it was a "relatively" easy and affordable fix.
Post #659837 19th Mar 2023 10:29pm
