Home > Maintenance & Mods (L405) > Part Number Help Please
AndyViking
United Kingdom 2017 Range Rover SVAutobiography SDV8 Corris Grey
Hi
After all the heavy rain I noticed my upper tailgate seemed to be filling with water and then drenching me with water when I opened it. I can't see any blocked drain holes, but it appears that a retaining clip of some sort is missing from one of the two rubber wiring ducts that go form the body shell into the top of the tailgate. It is a piece of rigid plastic, L-shaped with a scallop cut out of one side to allow it to fit around the duct. The non-scalloped side seems to cover a hole in the tailgate trim where I suspect the water is coming in.
I have tried to find the part number or a parts diagram online but to no avail. It seems a simple job to fit it and I would rather not have to pay a dealer £50 plus parts to do it if at all possible...
Can anyone help with a part number or a suitable parts diagram?
Thanks
Andrew 2018 SDV8 Autobiography (‘6Cool
2017 SDV8 SV Autobiography ('67)
2016 TDV8 Vogue SE ('66)
2008 D3 HSE
Post #652643 5th Jan 2023 3:04pm
Kot
Does this help https://new.lrcat.com/#!/12120/139242/139506/11318
Need to check its ok for 2017 2018 SE SDV8 4.4 Byron Blue
Post #652651 5th Jan 2023 5:32pm
AndyViking
Hi
Thanks but it’s the fixing that goes onto the rubber cable duct at the top of the upper tailgate I need. These ones are for the body shell side of things. I have found a parts diagram but it doesn’t show the part I need so it might be MY17 specific?
Will upload a photo when it’s daylight. 2018 SDV8 Autobiography (‘6Cool
2008 D3 HSE
Post #652713 5th Jan 2023 11:17pm
Phoenix
Is this what you're after?
Post #652714 5th Jan 2023 11:31pm
AndyViking
Yup - apart from 14603a on mine is a right angled hard plastic cap and not a flat grommet☹️ 2018 SDV8 Autobiography (‘6Cool
2008 D3 HSE
Post #652716 5th Jan 2023 11:52pm
AndyViking
Here are two photos of the offending parts:
The first one with the arrow shows the left hand side duct with what I can best describe as the grommet retaining clip in place (marked with an arrow). This is the missing part.
The second photo shows the right hand duct with the retaining clip missing and the duct clearly coming loose.
If anyone can help with the part number (or even a spare one of the clips) it would be really appreciated.
Thanks
2008 D3 HSE
Post #653078 9th Jan 2023 2:19pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
The images in the online parts catalogue do not always accurately depict the parts and sometimes the descriptions can be somewhat bizarre also!
It does seem that item 14603A (part no LR042890) is the part you require. The parts diagram shows one by each of the two loom sections that pass through the tailgate.
Post #653096 9th Jan 2023 6:25pm
AndyViking
Thanks for the part number. Indeed when I put it into the Interweb photos come up showing what looks to be the correct part. Three just ordered from John Craddock (assuming I break at least one of them!) so will let you know.
Thanks again 2018 SDV8 Autobiography (‘6Cool
2008 D3 HSE
Post #653107 9th Jan 2023 7:33pm
