Home > Technical (L405) > Soft close on L405
Curtis Bay
United Kingdom 2017 Range Rover Vogue SE SDV6 Barolo Black
Soft close on L405
Hello
I'm new to the forum having just bought a 2018 Vogue SE.
I have noticed that the front left hand door (UK car) does not soft close. If I push the door to the first latch I can hear the motor for the soft close but nothing moves. The door can be closed manually and stays closed / locked.
I have done a bit of digging on the internet and have found a replacement cog for the soft close motor / gearbox which appears to pull a cable. Is this the part I need to fix my problem and has anyone fitted one - I'm assuming it is quite involved.
Many thanks, Simon.
Post #652498 4th Jan 2023 1:50pm
have a read here Simon,
https://www.fullfatrr.com/forum/topic54247...soft+close ... - .- -.
Post #652501 4th Jan 2023 2:48pm
Curtis Bay
Thanks Stan
The symptoms of my door are a little different. The motor starts when it should (first latch) but does not move the door. If I push the door or use the handle it makes no difference. It is as though the motor is disconnected from the mechanical operation of the door but it functions electrically.
Post #652503 4th Jan 2023 2:55pm
