Home > Technical (L405) > L405 Tow Drop Plate Assembly Dimensions
Bigfella70
United Kingdom 2016 Range Rover Vogue SE SDV8 Santorini Black
Hi all, please could someone advise on the length of the tow neck assembly for the L405 compatible with the Landrover tow bar.
Part number is LR 036699 as pictured below.
I’m looking for one and have been offered a similar part from an L322 which is part number 323063. The hole for the locking pin looks in a different position for starters so just trying to confirm compatibility.
Thanks and all the best for new year Thumbs Up Current
2016 MY L405 SDV8
2018 VW Golf GT EVO
2001 BMW Z3 2.2
Previous
2002 L322 TD6
2004 Mercedes R230 SL350
1994 993 Carrera
Range Rover P38 x3
Range Rover 3.9 EFI
Post #652170 31st Dec 2022 12:57pm
I think you will find the 322 one has a smaller square that goes into the receiver on the fatty, it will fit in but is far too loose.... Pete
Post #652175 31st Dec 2022 2:05pm
D.Sloan
United Kingdom 2017 Range Rover Vogue TDV6 Firenze Red
The draw bar is 50 x 50 mm
Overall length of draw bar to rear of drop plate is 260 mm
Centre line of locking pin hole to bottom of locating notch is 97mm
Centre line if locking pin hole to inner end of draw bar 135 mm
Locking pin diameter 15 mm
Mine was supplied by Land Rover and has Westfalia part no eBay Item No. 323104621001 and fits late 2017 L405
Hth
If you need any other measurements just let me know
Happy New Year!
Dave
Post #652238 1st Jan 2023 12:55pm
D.Sloan
Sorry don’t know where the ebay bit came from but part no is correct!
Post #652239 1st Jan 2023 12:56pm
Bigfella70
Dave, thanks very much for taking the time to get these measurements. Very much appreciated!
Best regards.
Dave. Current
2016 MY L405 SDV8
2018 VW Golf GT EVO
2001 BMW Z3 2.2
Previous
2002 L322 TD6
1994 993 Carrera
Range Rover P38 x3
Range Rover 3.9 EFI
Post #652278 1st Jan 2023 7:29pm
D.Sloan
No problem Dave, hope you get sorted.
Post #652305 2nd Jan 2023 9:19am
