![]() | Home > Maintenance & Mods (L405) > L405 2018 boot won’t fully open |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 ![]() ![]() |
sounds like it's lost the calibration, IIRC, push open to the height you want it / maximum extent, then press and hold the button on the tailgate for three seconds or so until you hear a chime from the dash. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1677 ![]() ![]() ![]() |
Good advice from Pheonix above, also search “battery” threads on here as talgate issues can point to a weak battery or charging issues, the tailgate is the Barometer of the L405 battery. |
I forgot about that! if it will fully raise with the engine running, then it's a battery issue, if it's the same, then it needs recalibrating. |
Purso Member Since: 21 Jan 2018 Location: Bucks Posts: 12 ![]() ![]() |
That has sorted it thank you! |
@Pheonix,
