![]() | Home > Technical (L405) > Usage of N=Neutral when rolling? |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 793 ![]() ![]() ![]() |
The thread below is interesting, in short, do not do it downhill. If the car is still, at a long red light for instance, it's OK.
elsterracer Member Since: 29 Nov 2022 Location: Heilbronn Posts: 15 ![]() ![]() ![]() |
Hi adar,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
But not needed on the 8 speed box..... ![]() The standstill decoupling feature is new for the 8 speed transmission. When the vehicle comes to a standstill (with the brakes applied), the converter is disconnected from the driveline so that only a slight residual load remains. This further reduces fuel consumption. Pete I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
I know, but he really wants to shift to neutral... |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
Sitting at lights in neutral with the footbrake applied is bad for the gear selector electronics which will lead to premature faiure of the module. This is due to the shift interlock solenoid being powered for far longer than expected which overheats the current-limiting diode that allows the gearbox ecu to determine if the interlock solenoid has gone open circuit. Neutral + brake pedal is expected to be short duration which normally won't overheat the diode that doesn't have a suitable heat-sink to allow for extended use. Either the diode fails or the solder at the joints melts then resets crystalised which is then a high resistance joint, not allowing current to pass to the shift lock solenoid. |
