![]() | Home > Technical (L405) > Weird cold start problem RR 2013 TDV6 |
SmithCorona Member Since: 17 Feb 2017 Location: Elverum Posts: 3 ![]() ![]() |
A friend has a 2013 Range Rover Vogue 3.0 TDV6 258hp with a starting problem that drives him mad. Several garages, including the largest LR dealer in Norway, has tried to fix it but to no avail. Oddly, no OBD code is stored that can assist us! This is the second winter with the problem.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35504 ![]() ![]() |
is there an additional battery in the rear right cubby hole...if so check it , it might be flat.. ... - .- -.
Thanks, we will check as soon as possible. |
Icing of the MAF would also cause this, there was an issue on the TDV6 early on with MAF icing caused by cold wet air, there was a software fix (presumably to increase the current across the resistor) - I'd hope that if this also applies to the TDV8 the dealer would have checked the software level. |
Very interesting info - we are extremely thankful. Will look into all suggestions. Car is a TDV6 so the MAF icing problem may well be the case. Also the air hose problem is interesting. It reminds me of a problem I had with a otherwise very dependable Rover 75 V6 where a engine ventilation tube froze in a bend. I fixed this by covering the exposed tube with insulation foam.
If the MAF is icing, the measured values for air temperature and airflow will not be plausible, if you have any diagnostic tool that can read the values, it will show if icing is the problem or not.
