![]() | Home > Technical (L322) > Weak battery symptoms? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
what you describe suggests a new battery is required
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Or possibly a bad earth connection. |
h18ant Member Since: 07 Jul 2022 Location: East Sussex Posts: 14 ![]() ![]() |
Is a drop test normally done at a kwik fit kind of establishment??? |
havnt been to a kwik fit for ages so not sure...you could call them. ... - .- -.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1687 ![]() ![]() ![]() |
How old is the battery? I'd say if it's older than 3 years on a FFRR, you're on borrowed time especially with all those symptoms. Skip the drop test and count the saving as a discount of your new battery, fit the battery yourself to keep the cost down to just the battery, check out the Tayna website.
Thanks for the replies, the battery is just coming up to two years old |
What is the system voltage with the engine running, 1 min after start and no additional loads, what is the system voltage with the engine running and 'defrost' button pushed?
h18ant:
Thanks for all of the advice, appreciated! |
Sooo, before i went out for an adventure in the snow this morning, i started up the engine. It started fine but i had the same thing where it seems like if i put too many things on like the heated front screen, heated steering wheel and heated seats. None of it works. If I switch everything off then I can't put the heated screens back on for a while then after a few minutes, they will start up and actually demist and work.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Could be or it could be the alternator, follow phoenix's guidance above..... |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 760 ![]() ![]() |
What is the make and spec of the battery? a cheap undersized battery could well be US after only 2 years and there's plenty to suggest it is the battery.
Looks to be an AGM Lion and it was £229. Bought in December 2020, maybe it's a duffer... |
Will do, thanks. |
